  3. Import Image to Allegro
  • Replies 24
  • Views 28812
David G
David G over 16 years ago
Does anyone know if it is possible to import an image into allegro PCB editor,
would like to use image on silkscreen
dg
thanks
  • eDave
    eDave over 16 years ago
    Ok, those commands won't work with an L level license (Studio). If you have performance, change to that suite and try again.
    mkbitmap.exe and potrace.exe must both exist in the potrace folder?
    Dave
  • MAAC
    MAAC over 16 years ago
     Hi Dave,
    I tried from Performance option...
    Out of the mentioned commands the first three gave the result of t..rest all  undefined variable
    -MAAC
  • eDave
    #6 would always return a value if MAGICK_HOME was set correctly.
    Somehow your system variables are not being recognised by Skill.
    Are you running Windows XP? I don't have experience with Vista. Maybe it behaves differently.
  • MAAC
    oops i think i missed #6....it is giving the path  /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    "D:\\AllegroSite\\ImageMagick"
     i am using XP with SP3
