  3. How to make cutouts?
  • Subscribers 163
  • Views 6200
grom59
grom59 over 16 years ago
 Hello!
 How to make cutouts (square window) on PCB in Allegro design? Wich layer I must use?
  • oldmouldy
    oldmouldy over 16 years ago
    You could use Board Geometry / Outline to define the hole(s) and add Route Keepout / All around the hole to keep Copper / Routing clear. Add a note / details to the Assembly layer to describe requirements. When sending the data for fabrication, ensure that the fabricator is made aware of the hole requirements.
