  3. Importing Board Outline
  • Views 14251
rsr2b
rsr2b over 16 years ago
Hi, I am trying to import a board outline that is saved in a .dxf format into allegro. When I import it, I get an error that says - "Unable to start program; dxf2a". I have search online for dxf2a, but I cannot find anything about it. Does anyone know what it is. Thanks
  • redwire
    redwire over 16 years ago
    dxf2a stands for DXF to allegro.  It is in the install path under %CDS_ROOT%\tools\pcb\bin
    either you have a path problem or an install problem.  Probably best to file a report to Cadence help instead of debugging it here.
  • rsr2b
    Thanks for the info. I was missing dxf2a.exe. I got the file from a co-worker.
