  3. ERROR Packager-XL
  • Subscribers 162
  • Views 15854
ERROR Packager-XL
Tiger Woody
Tiger Woody over 16 years ago
#1 ERROR(SPCODD-213): Injected property name:value 'DESCRIPTION:IC, VOLTAGE~
REFERENCE, +5V OUTPUT, 8V TO 36V INPUT VOLTAGE RANGE, MAX TEMPCO: 2ppm/°C , S~
OIC8-150MIL' clashes with 'IC, VOLTAGE REFERENCE, +5V OUTPUT, 8V TO 36V INPUT ~
VOLTAGE RANGE, VIN(MAX)=-0.3V TO 40V, SOIC8-150MIL, 0degC TO +70degC' for PPT~
'MAX6250'. Multiple property name:value pairs might exist for a particular PP~
T property in the part table files that are being merged. Ensure that each PPT~
has a unique property name:value pair. Fix one of the property name:value pai~
rs listed in this message.
#2 ERROR(SPCODD-213): Injected property name:value 'VOLTAGE_RATING:+8V TO 3~
6V' clashes with 'N/A' for PPT 'MAX6250'. Multiple property name:value pairs m~
ight exist for a particular PPT property in the part table files that are bein~
g merged. Ensure that each PPT has a unique property name:value pair. Fix one ~
of the property name:value pairs listed in this message.
#3 ERROR(SPCODD-213): Injected property name:value 'DATASHEET_URL:http://17~
2.23.100.21/inv/attachfile/downloadfile.php?mode=open&id=0812-000588&fsize=190~
795' clashes with '172.23.100.21/.../downloadfile.php
pen&id=MAX6250AESA&fsize=917390' for PPT 'MAX6250'. Multiple property name:val~
ue pairs might exist for a particular PPT property in the part table files tha~
t are being merged. Ensure that each PPT has a unique property name:value pair~
. Fix one of the property name:value pairs listed in this message.
#4 ERROR(SPCODD-212): Could not merge PPT parts for PPT 'MAX6250'.
#5 ERROR(SPCODD-221): PPT 'MAX6250' was loaded from the following files:
INFO(SPCODD-223): ./mml_worklib/max6250/part_table/MAX6250ACSA.ptf
INFO(SPCODD-223): ./mml_worklib/max6250/part_table/max6250.ptf
#6 ERROR(SPCODD-229): Part selection not performed. Refer to previous erro~
r(s) regarding attempt to merge PPT 'MAX6250'.
  • EvanShultz
    EvanShultz over 16 years ago
     Hi Tiger,
    These problems are caused because you have multiple components with key properties that are the same. Look through the PTF files listed in the "#5 ERROR" section and resolve any conflicts. This may require some experimentation.
    I would encourage you to review internet etiquette and please provide some supporting information instead of just an error message. Tell us what's happening, has it happened before, what version of the software are you running, etc. so we can better help you. Some effort on your part may make a huge difference in the response that you receive.
