  3. Problem: Missing or invalid expression
  • Views 14678
Emmanuele
Emmanuele over 16 years ago
Hi to everybody.
I'm using Design Entry HDL (in Cadence SPB 16.01).
I would like to know if it's possible to define the value of an attribute (say, the resistance of a resistor) depending on the istantaneous value of a voltage or a current in the circuit.
I know that it's possible to define values which depend on constants, or fixed parameters; but I'd like to define comething more complex.
For instance, I'd like to define a resistor with a resistance depending on a function of the integral of the power dissipated in its (ie R*I^2).
I read some information on the manuals, but trying to run the simulation with the modified attributes I keep on getting "ERROR -- Missing or invalid expression" or the like...
Any suggestions?
Thanks a lot,
Emmanuele
  • Khurana
    Khurana over 16 years ago
     Yes, I think you can do that but not sure how exactly.
     There's an OrCAD forum at http://www.orcad.com/forums/ so try there.
