  3. Defining Copper thickness
  • Subscribers 163
  • Views 14670
tltoth
tltoth over 16 years ago
Someone wo uld explain me please, why 1.2 mils is the default copper thickness in the xsection dialog.
1.2mils = 0.03048mm
1oz copper is 35um thick that is 0,000035mm -> 0.001378mils
1.2mils 1000 times more then this.
  • tltoth
     Sorry. I made a big mistake
    35um is 1.3778 mils
  • redwire
    redwire over 16 years ago
    And after processing the final thickness for 1oz internal layers is around 1.20-1.25 mils.  External layers can be 2.0-2.2 mils after plating when using 0.5oz foil with 1oz plating.
