  3. Setting Dynamic Shape Parameters
  • Views 13919
ebstorrance
ebstorrance over 16 years ago
I am using Allegro 15.51 to generate dynamic shapes in my layout.  I would like to use orthoganal thermal reliefs component pins in some locations and at other locations on the same shape to use full contact pins.  Is there a way to do this using dynamic shapes?
  • Khurana
    Khurana over 16 years ago
     Yeah, I believe so.  Specify Shape level parameters that are different from pin level parameters (pin level parameters are specified by Edit > Properties > in Find Filter check Pin only > left click on pin > add desired property that begins with DYN prefix).
