  3. HOw to measure HWTC(hole wall to coductor spacing ) in ...
  • Views 671
HOw to measure HWTC(hole wall to coductor spacing ) in pCB
girish
girish over 16 years ago
 How to measure HWTC(Hole wall to Conductor spacing ) in PCB?( One of our fab house asking value should be greater than 8.25mil )
Girish Kumar
  • BillZ
    BillZ over 16 years ago
    In version 16.2 you can setup a DRC for Hole to Conductors in Constraint manager.
    Its in the spacing worksheet. Make sure the checks are enabled in the Anaylze menu in constraint manger. No need to measure if the rule is ment.
    BillZ
    EMA Design Automation
