  3. Who wants a free, cross-probing viewer for DEHDL and PCB...
  • Views 15609
Who wants a free, cross-probing viewer for DEHDL and PCB Editor?
EvanShultz
EvanShultz over 16 years ago
My company is not fulfilled by the PDF Publisher and FREE Physical Viewer and I'm hoping to foster a discussion of design viewing requirements from SPB users that leads to a request for better viewing tools. I am posting this to connect with other SPB users and bring this issue to Cadence's attention.
To my company, these are some typical uses for free, cross-probing viewers:
-an engineer working at a lab bench where editing the design is unneeded
-manufacturing folks, both local and global/contract, who need to analyze, check, and query the design for manufacture
-local and global service department who needs to be able to view design information when troubleshooting a failed product; global service centers may need technical help over the phone which is much easier with more powerful software tools
The inability to cross-probe between schematic and PCB is a huge limitation. Especially with hierarchical blocks, where net names can get easily confused, it becomes quite difficult to correlate the schematic and PCB. The only option is using the Find tools in Adobe Reader and the FREE Physical Viewer, which is far more painful than being able to choose either a schematic or PCB element and have it highlighted.
PDF Publisher is an improvement over a "dumb" PDF schematic, but it does not meet all the requirements. Having the Object Data Tool and the Model Tree are nice, but I still feel greatly limited by the ability to view and query the schematic versus DEHDL. And I have to pay for this inconvenience! The FREE Physical Viewer, however, isn't too bad. I'd like to see some of the features in Viewer Plus become part of the FREE Physical Viewer, but compared with PDF Publisher I can't really complain about viewing PCBs. The best solution would be viewer programs which are simply "watered down" versions of the full program without editing and saving options.
Our previous ECAD package was P-CAD, and if you've ever used the P-CAD viewer you'd understand the comparative absurdity of Cadence's current solution. P-CAD's viewer looks and feels much like the full version of P-CAD. And P-CAD had their viewers available in 2000! I am shocked that the methods for viewing a design are so inadequate, when many other ECAD suppliers provide free tools with the capabilities one would expect with any ECAD tool, let alone a pricey, otherwise very capable tool like SPB. Are the Cadence folks not paying any attention to the tools provided by their ECAD peers in addition to shunning the users who pay their salaries?
A lot of DEHDL and Allegro features are delightful, and I am quite happy to design PCBs using these tools, but would I gladly give up some of those features in order to have a viewer package which is useful and comparable with Cadence's competition? Yes. Do I feel cheated? Absolutely. Based on the quality and innovation in Allegro (and to a far lesser extent DEHDL), so I believe Cadence is fully capable of churning out cross-probing viewers that are top notch if they're motivated? You better believe it.
Cadence is built around a design flow and it works well in the forward direction. But after the design is finished and is in production, the software must assist a technician who has a physical old revision on the bench and needs to use the schematic and PCB to troubleshoot that board. Cadence needs to put more effort into post-design support. If we imagine the requirements of this technician, I think it's obvious that the current solution is inadequate. I hope we can show Cadence that their customers want and deserve robust, cross-probing viewers. The use of ECAD software doesn't end when 100% of the nets are routed, but that's where the usability of the SPB tools end.
And here is an issue which exists even in the full version of DEHDL - how can you easily search for elements? There needs to be a better way to find nets and components. If you have a product on your bench, and R52 is burnt, you need to find R52 on the schematic. You cannot tell me the Global Find form is easy to use in this case. A list of all components and nets, allowing you to view the properties or jump to the element, needs to be implemented. And this information needs to reflect the actual ref des and net name on the PCB, which isn't always the case with hierarchical blocks. A repair technician is likely to be starting from the PCB, so it needs to be easy to move from the PCB to the schematic when viewing designs. Obviously cross-probing would be of great help here, but just making it easier to find elements on the schematic would be of great use. The Find filter in the FREE Physical Viewer is usable, but not especially helpful, however it's an immense improvement on finding elements over DEHDL. Even the Object Data Tool mode of Adobe Reader puts DEHDL to shame when it comes to locating components and nets.
I understand the portability advantage of PDF files for the schematic. Plus the challenges in creating any portable file from the DEHDL information structure. But those technical challenges can undoubtedly be overcome. I could live with a variety of solutions as long as they did the job. The current design viewing solution does not, which means there is an opportunity for innovation by Cadence in coming up with a solution that will work for their customers.
As an engineer, I know full-featured cross-probing viewers would be useful nearly every day for me. But this is also about proper software support for the people who deal with a project after it has left the engineer's desk. These folks may not be intimately familiar with the design so they need a solution which is easy-to-use and efficient. I find the current PDF Publisher + FREE Physical Viewer "solution" shameful on Cadence's part, but what about you? Are you perfectly content with the PDF Publisher and FREE Physical Viewer? Or would you be interested in cross-probing viewers? Is this a critical element which is holding your company back? Please reply with your thoughts, suggestions, comments, and/or rants. Thanks!
  • EvanShultz
     42 views so far and no responses!?!? Are you all really satisfied with the current capabilities for viewing SPB design?? I find that incredibly hard to believe as the tools are plainly inadequate.
     OK then, how do you work with your SPB projects post-design? Are you using "dumb" schematics? PDF Publisher schematics? FREE Physical Viewer?
  • eDave
    eDave over 16 years ago
    We use PDF Publisher for schematics and the Valor Unversal Viewer (VUV) for layouts.
    It works well for us but I can see that a full cross-probing solution would be useful.
    Dave
  • EvanShultz
     Hi Dave,
     Thanks for the reply. May I ask in what situations you use the PDF Publisher and VUV design viewing tools? Production, service, etc.?
    Do you have issues with net names in hierarchical blocks not matching the physical net name? What about finding a net on a PDF Published schematic which has no Signal Name? Do you use the Object Data Tool in Adobe Reader? How do you find a schematic element if you're looking at a physical board?
    Did Cadence's FREE Physical Viewer not meet your needs? If not, why use VUV? Is it to allow one PCB viewing tool for board from multiple software packages?
  • eDave
    Ok. We also use some custom assembly drawings that we generate into PDFs via SVG - giving us searchable text.
    So...
    All our schematics are generated using the PDF Publisher. Once the tool was available I ran  script over our archived designs to generate all existing plots in this format. This format is used in all our online manuals, by our service organisation technicians and by our engineering staff - if they don't have access to Cadence tools.
    VUV is good for us because it is universally available and can view our arrays - great for our production team. We would like them to use the full-blown Valor tools to verify our designs but we are not there yet. Mentor's acquisition of Valor has put a fly in that ointment.
    As with the schematics, the technicians in the field generally now use our custom assembly drawings (in PDF format).
    As far as I know we have had no problems with net names not matching. Maybe that issue just hasn't been reported to me. We don't have nets on our schematics that have no signal names as far as I am aware.
    Because the schematic and layout PDF's are searchable, finding reference designators on either one is no problem. Cross-probing would be nicer but I haven't had the time to investigate the options for doing that using SVG.
    The physical viewer is OK but it requires distribution of the Allegro brd file - something we are not quite prepared to do yet. VUV is also Allegro version-independent so is an easier roll-out. Because we already geneate ODB++ for our board manufacturers no extra step is necessary.
    I hope this helps. Cadence should provide a tool to produce searchable assembly drawings using scalable vector graphics (SVG). The trick is to convert the refdes text into a real font (we use Helvetica). I would post an example if I was at work (It's Saturday morning here).
    Dave
  • EvanShultz
     Hi Dave,
     Thank you for the in-depth and informative reply. I can see how your solution eliminates some of the problems I have with the Cadence tools.
    If possible, I would appreciate being able to get an example and more information on your process. Particularly your auto-generation script for PDF Publisher. Does it work on Windows machines?
     Do you use the Object Data Tool in Adobe Reader? It provides a list of Components and Nets which are helpful. It's not quite perfect as far as I'm concerned, but it's better than the "Find" box in Adobe Reader. But perhaps your method of going through SVG first would be even better?
     Have you used the "Lock database" option in the File > Properties form of Allegro? I haven't but it might give you the security you're looking for to release BRD files?? Then again, ODB++ obviously works well (we use it too).
    Thanks for you comments on what you think Cadence "should" provide! That's exactly what I'm hoping to do with this thread - get requests from users about what we want, regarding viewing SPB designs outside of Concept and Allegro, for Cadence's consideration.
