  3. How to specify the pin pair in pro delay constraints
  • Subscribers 163
  • Views 15295
ZhangCheng
ZhangCheng over 16 years ago
Hi all,
 In my FPGA-DDR2 design, on the net of A8, there is a pullup resistor. Please refer the attached pix for the layout on my board.
The path I need to control prop delay is from FPGA to DDR2. But in Allegro, pin pairs on this net is R-FPGA or R-DDR2, as following from information on this net:
            < NET >
  Net Name:            DDR2_A8
  Member of Bus:       DDR2_ADDR
  Pin count:              3
  Via count:              2
  Total etch length:      1582.389 MIL
  Total manhattan length: 1652.899 MIL
  Percent manhattan:      95.73%
  Pin                     Type      SigNoise Model        Location
  U2.T29                  BI        CDSDefaultIO          (5652.756 3039.055)
  P2.93                   IN        CDSDefaultInput       (6383.000 2921.728)
  RP8.1                   UNSPEC    DEFAULT_RESISTOR_PACK_4_47OHM (6899.800 2633.200)
  No connections remaining
  Properties attached to net
    LOGICAL_PATH      = @\penguin-1\.schematic1(sch_1):ddr2_a8
    FSP_NET           = DDR2_A<0>
    BUS_NAME          = DDR2_ADDR
  Electrical Constraints assigned to net
    prop delay: from AD to AR  min=1600.000 MIL  max=2200 ns
    relative prop delay: global group DDR2_ADDR_CTRL_CLK from AD to AR  delta=0.000 MIL  tol=280.000 MIL
    max parallelism: 300 MIL length at 6 MIL separation
    max parallelism: 600 MIL length at 7 MIL separation
    max parallelism: 1000 MIL length at 8 MIL separation
    max parallelism: 2000 MIL length at 10 MIL separation
    FSP_NET: DDR2_A<0>
  Constraint information:
    (Dly) RP8.1 to U2.T29  max= 2200ns  actual= 1447.605 MIL  (0.235986ns)
            (6899.800,2633.200) pin RP8.1,UNSPEC,TOP/TOP
      767.468 MIL (0.114477ns) cline TOP
            (6258.000,2898.109) via TOP/BOTTOM
      652.3 MIL (0.117235ns) cline SIG4
            (5672.440,3058.740) via TOP/BOTTOM
      27.838 MIL (0.00427453ns) cline TOP
            (5652.756,3039.055) pin U2.T29,BI,TOP/TOP
    (Dly) RP8.1 to P2.93  min= 1600 MIL  actual= 902.251 MIL
      767.468 MIL cline TOP
      134.783 MIL cline BOTTOM
            (6383.000,2921.728) pin P2.93,IN,BOTTOM/BOTTOM
    (RDly) RP8.1 to U2.T29  min= 2056.43 MIL  max= 2616.43 MIL  actual= 1447.605 MIL
                   target=  (DDR2_CKE0) RP5.2 to U2.U31
      652.3 MIL cline SIG4
      27.838 MIL cline TOP
  Member of Groups:
    MATCH_GROUP     : DDR2_ADDR_CTRL_CLK
    BUS             : DDR2_ADDR
    PHYSICAL & SPACING NETCLASS: 8MIL
Can anybody give me some advice to make control on the path from FPGA to DDR2?
Thanks!
  • Mike Veal
    Mike Veal over 16 years ago
     You should be able to right click the Xnet in constraint manager and select create - pin pair.
    This might help too:
    http://www.cadence.com/rl/Resources/conference_papers/stp_cdnliveemea07_ddrconstraints_veal.pdf
  • ZhangCheng
    Pin Pair can not be chosed to be desired.
    However, the document you wrote is very helpful! Thanks!
