  3. Set Constraints for Specific Region
  • Views 13252
Tanveer
Tanveer over 16 years ago
Hi all,
I have an impedence control board which have minimum line width of 12mil. but I have some ic's of tight pitch so I can't rout from these ic's by 12mils. Can I set minimum line width less than 12 in these specific areas so that drc's will not shown. I dont want to waive drc's.
regards
Tanveer
  • BillZ
    BillZ over 16 years ago
    You can setup regions  rules if you have AllegroL with the Performance option or above.
    You added an unfilled shape to the Constraint region Class using the Shape menu.
    BillZ
    EMA Design Automation
  • Tanveer
    Hi BillZ,
    Thanx for quick reply. I added an unfilled shape in Constraint Region Class I try to set the constraints for this region in cnstraints manager but I could not. plz help.
    Regards
    Tanveer
  • Tanveer
     Thanx BillZ,
    I have done it. thanx for your guidance.
    Regards
    Tanveer
