  3. Allegro Netlist error
  • Views 13980
FFSDEV
FFSDEV over 16 years ago
Please could anyone tell me what how do I get rid of this error in Orcad 10.3? I am trying to generate an allegro netlist and have tried a few simple tricks sucha s re-creatign teh design file and part etc but the error still persists.
“packaging the design view...#228 DDB_ERROR: Cannot package the primitive instance '@\main board\.schematic1(sch_1):ins13143800@ffs_parts.\gtl2003bq.normal\(chips)' in any sections of the physical part 'GTL2003BQ_SM_QFN20_19P685_166X0'.  Check the pin definitions for each section in the chips_prt file.
#53 DDB_ERROR: Null object id specified in call to ddbPackInstInSections.
Error: Line 0 in file :
        Could not pack inst <instId->OPName> in sections
      Detected in function: ddbiPkgDesign
#53 DDB_ERROR: Null object id specified in call to ddbStopGen.”
  • oldmouldy
    oldmouldy over 16 years ago
    10.3 is quite an old version now and some of the specifics with Allegro netlisting messages may well be lost in time. I suggest that you start with a Design Rules Check, Tools>Design Rules Check, enable all the checks except "SDT Compatibility" and see what you get, look into all the errors and see if there are any specific to the part in question. The netlister will have attempted to build a primitive to hold the pins of the part, when it comes to actually place the pins into the primitive, the netlister cannot find a consistent match between the pins and the primitive created.
    Without the DSN file, investigating this remotely will be virtually impossible.
  • FFSDEV
    Thanks for your feedback. I know 10.3 is old but thats all that I got for now.
    Anyways I finally found the problem. Apparently you can’t have invisible power pins with the same name as a visible power pin. I had changed the pads for three parts to invisible power pins named GND so that they would be attached to the GND power net. Each of these parts also had other pin(s) named GND that were visible. If I change the visible pin names to something else or I changed the invisible pins to visible pins the cryptic netlisting error doesn’t occur.
     Thanks for the input.
  • DKHINKLE
    DKHINKLE over 15 years ago
    I ran into this same problem with OrCAD version 16.2 (getting the same undocumented errors), and following this advice fixed it.  Thanks!
