  3. PSpice generated file in OrCAD Capture
  • Views 12610
kanghc85
kanghc85 over 15 years ago
Hello!
I am a learner,when I ask ORCAD to generate a file,there is a mistake,the output file is as follows:I don't know how to solve it,
thank you!
kang
*Analysis directives:
.AC DEC 10 10kHz 3MHz
ERROR -- Invalid value
.MC 30 AC V([OUT]) YMAX OUTPUT FIRST 30
.PROBE
.INC "002-SCHEMATIC1.net"
**** INCLUDING 002-SCHEMATIC1.net ****
* source 002
X_U1A         N00035 N00045 N00321 N00220 N00091 LM324
X_U2A         N00094 N00162 N00324 N00179 OUT LM324
R_R2         0 N00045  50k
R_R3         N00045 N00091  50k
R_R4         0 N00162  50k
C_C1         N00029 N00035  0.1u
V_V1         N00029 0 DC 0Vdc AC 2Vac
C_C2         0 N00094  0.0022u
V_V5         N00321 0 10Vdc
V_V3         N00324 0 10Vdc
V_V2         N00220 0 -10Vdc
V_V4         N00179 0 -10Vdc
R_R1         0 N00035 Rbreak 10k
R_R5         N00091 N00094  10k
R_R6         N00162 OUT  50k
.PRINT         TRAN V([OUT])
**** RESUMING 002-schematic1-1.sim.cir ****
.INC "002-SCHEMATIC1.als"
**** INCLUDING 002-SCHEMATIC1.als ****
.ALIASES
X_U1A           U1A(+=N00035 -=N00045 V+=N00321 V-=N00220 OUT=N00091 )
X_U2A           U2A(+=N00094 -=N00162 V+=N00324 V-=N00179 OUT=OUT )
R_R2            R2(1=0 2=N00045 )
R_R3            R3(1=N00045 2=N00091 )
R_R4            R4(1=0 2=N00162 )
C_C1            C1(1=N00029 2=N00035 )
V_V1            V1(+=N00029 -=0 )
C_C2            C2(1=0 2=N00094 )
V_V5            V5(+=N00321 -=0 )
V_V3            V3(+=N00324 -=0 )
V_V2            V2(+=N00220 -=0 )
V_V4            V4(+=N00179 -=0 )
R_R1            R1(1=0 2=N00035 )
R_R5            R5(1=N00091 2=N00094 )
R_R6            R6(1=N00162 2=OUT )
_    _(out=OUT)
.ENDALIASES
.END
  • tltoth
    tltoth over 15 years ago
     PSpice is not case sensitive. That is 3MHz is 3 milli Hz, less then the start value 10kHz
    Try 3megHz or 3MegHz or 3MeGHZ or 3meg instead
  • kanghc85
    Thanks again,
    The problem is solved,you have pointed the key problem!
