  3. change package symbol
  • Subscribers 163
  • Views 14960
rlenser
rlenser over 16 years ago
I am new to OrCAD PCB Designer after using Layout for about 10 years.  I have finished my first PCB, but in the design review a resistor changed from 1W to 5W.  I have the new package symbol, but I can't figure out how to update the PCB with it.  Any help will be greatly appreciated.
- Richard
  • redwire
    redwire over 16 years ago
    How did you assign it in the first place?  And, are you using the netlister?
    Hint: change the pcb_footprint property in OrCAD (schematic) and re-netlist the board.  The package will automatically update in OrCAD PCB.
  • rlenser
    Yes, re-netlisting worked perfectly.  It is just more steps than I was used to.  Thanks for your help!
  • redwire
    Allegro is a netlist driven tool so it prefers to have the changes come from top down...
    Some tools allow the layout to drive the netlist which is a problem with Allegro...but you can do it with the proper license (logic edit->enable).
