  3. Concept HDL-Footprint Assignment
  • Subscribers 163
  • Views 15530
Vijay143
Vijay143 over 16 years ago
Is it possible to assign two or more footprints for a single  symbol in Concept HDL schematic.
If yes how? If anybody knows pls tell me.
Vijay
  • steve
    steve over 16 years ago
    Inside Part Developer there is an option to add Jedec_Type which is the preferred footprint but also you can add Alt Symbols which is the extra footprints you require.
  • Vijay143
    Thank you steve.
    Infact I want to know whether we can assign different part numbers and footprints for the same symbol???
    Vijay
  • steve
    Vijay
    Yes you can. You new to use a part table inside Part Developer. Here you can add all sorts of variants under the same symbol. Under your install directory there is a doc folder. In there look for pdv.pdf. This is a user guide for part developer and has details on part table files.
