  3. PCB Editor ratsnest color and range and shape edit
  • Views 14275
stellar
stellar over 16 years ago
 All my ratsnests are yellow. I don't see a way to set the color of a net.
Is there a way to simply select the edge or corner of a shape to resize it?
 Is there a way to limit the range of ratsnests? I'd like to be able to choose a window and have the rats limited to that window so it will be easier to focus on those components first.
 Sorry another question but what exactly is a pad on a layer that doesn't have a net connected to it? I see something about suppressing them at artwork generation time but I think the padstack has to be set to automatic. I don't recall Layout having such pads but maybe it did.
  • oldmouldy
    oldmouldy over 16 years ago
    If you are running version 16.2, go to Display>Color / Visibility, below the File menu, check the button for "Nets", that will set the dialog for colouring nets.
    Shape>Select Shape or Void, left-click in the shape to select it, small squares, "handbags" will appear at the corners of the shape, as you approach a draggable entity, like a line or the corner, with the mouse, the moucursor will turn to a double-headed arrow, left-click and drag the mouse at the point to drag the entity to resize the shape.
    Display>Blank Rats>All to remove the rat display, Display>Show Rats>Net, pick the nets. Use the Find Filter to get a list of nets, if required.
    Under normal circumstances, you get "Regular Pads" everywhere, if there are any dynamic copper shapes, the DRC clearance will be added to the regular pad to void the copper shape, or add thermal spoks as specified. Generally you only need to supress the pads in dense designs.
  • stellar
    Okay on the shape edit method. I was just selecting shapes in the find filter which doesn't get you to edit mode. Thanks.
