  3. Routing nets with propagation delay
  • Subscribers 163
  • Views 13938
Neha Anu
Neha Anu over 16 years ago
Hi to all,
I'm currently using the specctra autorouter.I tried to route the some nets that have same driver and receiver and set propagation delay for that nets in the constraint manager.I've then autorouted the .brd file using the .do file by grouping the netsand giving the commands to route that file.But some of the nets are not obeying the delay rule y??Can anyone plssss xplain this??
Thanx
Neha
  • redwire
    redwire over 16 years ago
     a) No license to match
    b) If you have a license and still does not match then you should try just routing that match group alone using the command line and look at the results log.  Something is preventing from matching...
  • redwire
