  3. Autoroute nets that have propagation delay and relative...
  • Subscribers 166
  • Views 15547
Autoroute nets that have propagation delay and relative propagation delay
Neha Anu
Neha Anu over 16 years ago
Hi all,
I've  to autoroute nets (A1,A2..A8) that are matchgrouped (MG1) with pin pair longest pin pair and with propagation delay .
How can I autoroute the above nets using the do file in the Specctra autorouter using the command Route->Route Editor??
Can anyone plsss xplain wats the do file command for the above scenario??
Thanx
Neha.
  • steve
    steve over 16 years ago
    A asked in another post what level of license are your running ?
  • Neha Anu
    Hi, I'm using Cadence base Version 16.0.
  • redwire
    redwire over 16 years ago
     I believe you need the "performance L" license as a minimum to route these in Specctra.
    http://www.cadence.com/rl/Resources/datasheets/7432_PCB_Designs_FINAL.pdf
  • Neha Anu
    Is "performance L" is really needed for autorouting the board in specctra with  .do fileusing the command Route->Route Editor from Allegro PCB Design GXL ??Is it not possible to route with the simple commands to meet both the propagation and relative propagational delay??
    Thanx
    Neha
  • steve
    The tools is seperated into different levels
    Orcad PCB Designer, Allegro PCB Design L, Allegro PCB Performance L, Allegro PCB Design XL and Allegro PCB Design GXL. You need at least a Allegro PCB Performance L license to route what you need. Find out by going to Help - About. It is quite clear about the level of tools you have.
