  3. How Voltage related to trace width ?
  • Views 16085
girish
girish over 16 years ago
Good day to all !
Is there any dependency of Voltage on the track thickness & width ?.
I want route power signal of 24V @2A for a distance of 2inch , planning  to use 40mil trace width(microstrip ,1OZ copper thickness, assuming temp 21C) as per the current calculation.For voltage rating is there any relation?
Girish Kumar
  • tltoth
    tltoth over 16 years ago
    The answer is NO. The tracks spacing depends on voltage differential between them.
    The track thickness and width depends on the current it has to withstand.
  • tltoth
     And also on which layer the track is located.
    details in IPC 2221  standard
     Seach for "PCB trace width calculator" in google
  • girish
    Thank u very much for the clarification ...!
    As I mentioned track located in the outer layer (microstrip) ,if I am routing in signal layer I will double the trace width .
    I have claculated the trace width for current capacity ,only worried whether I need to do any claculation for voltage also ?(since it is 24V).
    REgards,
    Girish Kumar
  • tltoth
    For 16-30Vpp voltage differential the clearance is approximately min 0.3mm
    But you know "More is Better"
  • purikku22
    purikku22 over 16 years ago
    in our case, 13-25V potential difference , we use 0.5mm clearance.
    > You received this email because you subscribed to notifications for
    > the Cadence PCB Design Forum. To unsubscribe, log in, go to forums,
    > and change your forum subscriptions.
    > http://www.cadence.com/community/forums/ForumSubscriptions.aspx
