  3. Autorouting
  • Views 13370
Autorouting
Neha Anu
Neha Anu over 16 years ago
Hi all,
I'm routing 8 signals from the BGA having relative propagational delay and propagational delay. I am trying to do it in specctra autorouter by giving length matching constraints given with a toal propagation delay in mils which is less than manhattan distance all these routing is done with the usage of .do files.But the group is not matching moreover the total delay constraint is not meeting.The autorouter is taking some other way to route the signals.It is not considering as a bus,even though i grouped them into bus.Can anyone give a solution to this??
  • redwire
    redwire over 16 years ago
     Post up a zip file of the board with explicit instructions on what you are doing (or post the specctra.did file with it) and I can take a look.  There are many reasons it won't work when the setup is wrong.
  • oscar migs
    oscar migs over 16 years ago
    Sounds like a lot of rules. Disable relative prop delay, then run it.  If that doesn't work use the command "circuit net" to control manhattan.
    Best regards,
    -oscar
