  3. Allegro subdrawing text
  • Subscribers 163
  • Views 14606
Lock2002
Lock2002 over 16 years ago
How do you handle subdrawing text? I have a design that I created a list of fabrication notes in and then exported it as a subdrawing. I tried to import into a different design, but all of the text does not import. I can create a text block that matches the subdrawing and it imports fine but there should be an easier way to set this up so it does it automatically.
  • Rik Lee
    Rik Lee over 16 years ago
    Is the text that is not imported on a user defined subclass that doesn't exist in the new drawing? The classes/subclasses that are in the subdrawing must exist in the drawing that the clip files are being imported to.
    What is in the log file (clipboard.log) from the import subdrawing session?
