  3. Pick n place data from OrCAD PCB Designer-16.2
  • Views 13472
MAAC
MAAC over 16 years ago
Is there any way wherein i can generate the pick n place data from OrCAD PCB Designer 16.2 with the format attached(not the default one which gives XY Coordinates).
Thnx
  • SMD_PicknPlace.txt
  • Nagaraj Shanmu
    Nagaraj Shanmu over 16 years ago
    explain what is Mid X         Mid Y         Ref X         Ref Y Pad X         Pad Y Comment?
  • EvanShultz
    EvanShultz over 16 years ago
    You can using a SKILL report. See the rep_bom_ignore.il program from the Allegro SKILL repository in COS. That should give you all you need to make your own report with the data you want.
    It seems to me using axlDBGetDesign() rather than using Extracta (as in rep_bom_ignore.il) to get the board information would be easier.
