  3. Adding a pad to a footprint? - in Allegro
  • Subscribers 163
  • Views 4161
JGeens
JGeens over 16 years ago
How do you add a (smd) pad to a footprint in Allegro?
I've created 2 smdpad.Then I used the package wizard to create a footprint. But I want to replace 2 pads with another size of pad...
 How can I do this?
  • tonychen
    tonychen over 16 years ago
    you can replace the pad  from the Tools->padstacks->replace
     but you should put the .pad file into the path you have defined in the user reference ,design path , padpath
    hope this can help you~
  • JGeens
     When I do this:Tools->padstacks->replace - click on the pad
    It gives an error: E- Symbol and Pin must be '*' when replace = old.
    What do I have to do next?
  • redwire
    redwire over 16 years ago
     Go back into the part editor (open up the .dra file) and replace the pad correctly in your library. Then in the board editor (.brd file), do a pakage update and the part with the corrected pads will show up.
    Make sure your paths are set up correctly to find the updates properly.
  • JGeens
    Thnx for the answers ,
    But how can I add 2 different pads to one footprint? The IC I'm making a footprint for requires 6 pads (2 different sizes). How can I do this? If I use the footprint wizard (package wizard), I can only select 1 pad.
