  3. Batch netlisting from Orcad Capture
  • Views 17106
Geoff
Geoff over 16 years ago
 Is it possible to output a netlist from Orcad capture, from the Dos command line?
 thanks
- Geoff
  • oldmouldy
    oldmouldy over 16 years ago
    Almost certainly not, as far as I can tell, command line options force "CIS" Option mode, "-CIS", and set the Capture.ini location, "-i"
  • jch teyssier
    jch teyssier over 16 years ago
     Of course you can:
    pstswp.exe -pst -d mydesign.DSN -n allegro -c %mypath%/allegro.cfg -v 3
    works great and no licence required.
    Jean-Charles
  • Geoff
     I tried that. it worked the first time, but afterwards I get:  Error [ALG0029] Unable to open file "c:\data\projects\testbrd\orcad\allegro\allegro/netlist.log" for writing.
    Also, I would like to know what the various command line switches mean. Eventually I want to output a netlist in "Dump" format.
    Geoff
  • jch teyssier
     Geof,
     does allegro directory exist? Do you get the 3 .dat files?
     -d : the .dsn
    -n : output directory
    -c : configuration file
    -v ; number of versions stored (,1 ,2 ...)
    -pst: export mode (i guess...)
    Type pstswp in sourcelink
    Solution ID:11103974
  • Geoff
     Thanks for the info Jean-Charles
    Unfortunately I still get the error message. I'll keep working on it when I have time.
    - Geoff
