  3. Help in 16.2 (create fanout)
  • Subscribers 163
  • Views 15114
luanvn81
luanvn81 over 16 years ago
 I runed "create fanout" command on a IC in allegro 16.2 and show element one via created , it like this:
            < VIA >
  origin-xy:    (304.9000 152.9350)
  part of net name:  ZZZ_R2229P1
  Connected lines:     1 ( BOTTOM )
  Padstack name:   VIA03_06_08_045
  padstack defined from TOP to BOTTOM
  rotation:  0.000  degrees
  via is not mirrored
  Symbol via: Ic2202
 It is a symbol via, and I don't want this.
How can I create fanout with nomal via ( not symbol via) ?
  Thanks.
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    Create fanout has used a normal via, but in the process it will mark it as a symbol via so that it moves together with the symbol.
    If you don't like this, go to the Route menu and select Convert->Unmark
    Best regards
    Ole
  • luanvn81
     Thank you for your answer.I have done follow your instructions and it's Ok.
    thank.
    Luan.
  • luanvn81
     Hi Ejlersen !
    Thank you for your  answer about Create Fanout. Today I have a problem that I hope you can help me. In 16.2, I goto Setup/ Unused Pads Suppression and try to run it. It's OK, but It apply to whole Board , but I want to  apply for only in BGA area . How can i do it ?
    Thanks.
    Luan.
  • Rik Lee
    Rik Lee over 16 years ago
     The Unused Pad Suppression feature is a global feature and cannot be applied to regions or components.
    ~Rik
  • Randy R
    Randy R over 16 years ago
    You could use two different padstacks.  One in the BGA region with "optional" pads and one outside of the BGA region that doesn't have optional pads (I forget the exact wording in padstack designer).
