  3. Scheduling a change in the time step of a simulation using...
  • Views 14598
Scheduling a change in the time step of a simulation using AMS Simulator
Emmanuele
Emmanuele over 15 years ago
Hi to everybody.
I'm running a transient simulation using AMS Simulator.
The simulation consists in long periods in which the voltages and currents of the circuit remain unchanged, alternated with short periods in which they vary quickly.
The point is: to have a good resolution in the short periods, I have to set a small time step for the simulation; but this way I use a small time step for ALL the circuit, and the simulation takes a lot of time.
My ideal solution would be to have the possibility to schedule a change in the time step during the simulation.
In the AMS Simulator manual I read that with the function OPTION one can set scheduled changes for some simulation parameters, but not for the time step.
Any suggestions?
Thanks a lot,
Emmanuele
  • oldmouldy
    oldmouldy over 15 years ago
    If you are looking at the "Maximum Step Size" try the following:
    {schedule(0s,0.1u,10us,0,20us,0.2u)}
    Note the statement is enclosed by "curly braces" and the parameters by "round brackets".
    This statement will schedule the Maximum Time Step to be 0.1u from 0 to 10us, then "undefined" - deteremined by PSpice / AMS Simulator - from 10us to 20us, then 0.2u for the rest of the simulation.
  • Emmanuele
    Thank you for your reply.
    I've just tried that command, but I think it worked only for the old PSpice...
    Anyway, it didn't work for me... (I got an "ERROR -- Invalid device")
