  3. Problem in "Place Database Part"
  • Subscribers 167
  • Views 4635
Zina
Zina over 15 years ago
blank_pageHi All !
I am using OrCAD Capture CIS 10.5.
I have a problem in this command:
'Place -> Database Part'.
When I select page 'Internet Component Assistant', I get a message of error 404: "The page cannot be found".
It is new problem, few days (or weeks) ago this command worked properly.
I had an advice to open URL  http://cds.orcad.com/ap_home.asp? by Internet Explorer.
I opened it and I can find the components, but I cannot place the part to my scheme.
Help me please !
  • oldmouldy
    oldmouldy over 15 years ago
    That is correct, since the 16.3 release last week, versions 16.2 or 16.3 are required to access the ICA - basically the current or previous releases are now required.
  • Debrah
    Debrah over 15 years ago
     I too tried this before, try it again. Please let me know the command/error you are getting.
  • nikhil ti
    nikhil ti over 15 years ago
    Hi
    I am currently using Capture CIS 16.0. I am currently trying to use the place -> database part -> Internet Component Assistant", I get error 404: "The page cannot be found". I have attached the file to this post.
    The link that it is trying to open is http://cds.orcad.com/entitymgmt/sLogin.jsp?PlaceMode=YES&FirstPlaceMode=YES&DISTRIBUTOR=Allied++++++++++++++++++++++++++%3bDigi-Key++++++++++++++++++++++++%3bMarshall++++++++++++++++++++++++%3bNUHorizons++++++++++++++++++++++&USER_NAME=&USER_COMPANY=&USER_REG=&PRODUCT_NAME=OrCAD+Capture+CIS+16.0.0.p001
    I am seeing the same error screen mentioned by the above cadence user. Is there any place where I can change the URL to http://cds.orcad.com/ap_home.asp so that I can get started with my design else what is the solution?
  • oldmouldy
    The ICA now requires at least version 16.2 of the tools to gain access, if you are running version 16.0 or earlier, you will be getting the "page not found" since you are not running the version required to view the page. IF you need to use the ICA, you will need to be running at least version 16.2 of the tools.
  • Zina
     Thank you
    I have not  version 16.2
    How I can get it ?
    Do I need to pay ?
