  3. Dimensions
  • Subscribers 163
  • Views 14108
Dimensions
David G
David G over 16 years ago
Hi to all,
does anyone know if PCB editor is able to do line dimentions having the units (inch, mm, etc) trailing the dimension
so far, I only been able to have PCB editor output the number :(
david
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    To my knowledge this is not possible.
    Best regards
    Ole
  • Cadpro2K
    Cadpro2K over 16 years ago
    Normally the 2nd NOTE in my NOTES: UNLESS OTHERWISE SPECIFIED calls out the UNITS defined on the drawing. I've also seen it called out down near the title block, but I like my use better.
    Good day.
