  3. Documentation Schematic Generation in SCM
  • Views 13208
PherricOxide
PherricOxide over 15 years ago
Inside Allegro System Architect SCM there is the option to generate a schematic from a project under Project -> Generate Schematics, which launches the "Documentation Schematic Generation" window. Is there any way to do this from the SCM TCL API or using command line tools instead?
I've looked through the projectTcl.tcl file as well as the list of TCL commands for SCM and have found nothing useful; I've also attempted to reproduce the behavior via calls to genviewHDL.exe, pxl.exe, concept2cm.exe, and other tools that I see SCM making use of, but I don't really know what many of them are doing and where different temp files they need are used (is there anyplace I can find documentation for these?).
