  3. userguides or help for each spice model
  • Subscribers 162
  • Views 14732
MAAC
MAAC over 16 years ago
 Is there any userguide or help which will give the detail of the models of spice library of OrCAD-16.2...i am searching for a guide which gives me the specificatinons of each model not the lib_list kind of guide.
Thnx
  • EvanShultz
    EvanShultz over 16 years ago
     Hi MAAC,
    You can use the Model Editor (Start menu > Cadence > Release 16.3 > AMS Simulator > Simulation Accessories > Model Editor) to open the device models for any part. In Model Editor, browse to the LIB files at $CDSROOT\tools\pspice\library. For primitive models it's fairly straightforward, but you'll probably need to consult the PSpice documentation for subcircuits if you're not familiar with SPICE syntax. Check out the documentation for a variety of ways to view the models besides just the SPICE model code. Be warned that most of the devices will simulate (some very well), but they may not represent the real device perfectly.
    If you want a synopsis of all the devices included with 16.2 so you can compare one transistor with another one without running multiple simulations and doing a side-by-side comparison in PSpice, I don't know but I'd love to find out. You best bet might be measuring the actual devices and/or checking the device datasheet(s).
    Is that what you're looking for?
  • tltoth
    tltoth over 16 years ago
    There is also a "PSpice A/D Reference Guide"  ...\doc\pspcref\pspcref.pdf
    where the models and parameters are specified.
  • MAAC
    tltoth,
    this is wht i was looking for..thnx
