  3. Running ODB++ from the command line
  • Replies 8
  • Views 19756
CADcaveman
CADcaveman over 15 years ago
 Hello all has anyone ever tried running the brd2odb command from a command line.When I run I get this error message that makes no sense at all as most error messages are nonsense. It makes no sense because the files it is complaining about not finding are in fact there.
$ brd2odb -d -gz -jn CU03_08A.odb CU0310708-00-A.brd
Initializing the translator environment...
***********ERROR      08Jan2010.121243.636  5480 BRD2ODB 7.6.4(32) Windows XP
Required file is missing : '/cygdrive/c/Valor/ODB++Inside/nv/bin/compress.exe'
Required file is missing : '/cygdrive/c/Valor/ODB++Inside/nv/bin/gzip.exe'
Required file is missing : '/cygdrive/c/Valor/ODB++Inside/nv/bin/tar.exe'
***********ERROR      08Jan2010.121243.652  5480 BRD2ODB 7.6.4(32) Windows XP
Required file is missing : '/cygdrive/c/Valor/ODB++Inside/nv/bin/csh.exe'
Status raised : module - G:/s76/translators/brd2odb/brd2odb.c, line - 217
Failed to initialize the translator !
  • djhutchi
    djhutchi over 15 years ago
    You might need to update your command line path setting to include the Valor paths directly, in a DOS ‘command prompt’ window I used
    set path=%path%;C:\Valor\ODB++Inside;C:\Valor\ODB++Inside\nv\bin
    Then it worked correctly for me:
    P:\temp>brd2odb -gz -jn test.odb -ijp . test.brd
    Initialzation Done !
    <<deleted>>
    Translation completed successfully.
    Translation Finished Successfully.
    T r a n s l a t i o n   e n d e d    s u c c e s s f u l l y
    P:\temp>
  • CADcaveman
    No that didn’t work either
    U:\scripts\allegro_archive_SPB16_01>setpath=%path%;C:\Valor\ODB++Inside;C:\Valor
    \ODB++Inside\nv\bin
    'setpath' is not recognized as an internal or external command,
    operable program or batch file.
    U:\scripts\allegro_archive_SPB16_01>set path=%path%;C:\Valor\ODB++Inside;C:\Valo
    U:\scripts\allegro_archive_SPB16_01>brd2odb -gz -jn CU03_08A.odb -ijp CU0310708-
    00-A.brd
    The following options were selected:
    Output ODB++ job name : cu03_08a.odb
    Output ODB++ job path : U:\scripts\allegro_archive_SPB16_01
    EDA Input job path : CU0310708-00-A.brd
    Log path : U:\scripts\allegro_archive_SPB16_01
    Write log messages to new log file
    Compression : enabled
    Output job format: ODB++ format
    Read DRC feature : Disabled
    Symbol Tolerance : 0.200000 mils
    Outline Size     : 0.100000 inches
    Component outline by : Place Bound
    Padflash : Ignore
    Allegro 14.0 thermal symbols : No
    No Thermal file/model were selected
    Suppress Shape Fill Source from Films
    Skip Refdes with Asterisk: No
    Read SQA data: Enabled
    Translate symbols: Yes
    Profile Symbol Type : Round
    Translating Job 'CU0310708-00-A.brd'...
    Windows platform
    Status raised : module - G:\s82\eif\eif_cadence.c, line - 3000
    Status raised : module - G:\s82\eif\eif_cadence.c, line - 2734
    *********** ERROR INTERNAL 08Jan2010.162611.339  868  8.2.0(86) Windows XP
    (ind_list != NULL && ind_list->magic == IND_LIST_MAGIC) at G:\s82\gen\gen_sort.c
     1236
    Status raised : module - G:\s82\eif\eif_cadence.c, line - 2276
    Status raised : module - G:\s82\eif\eif_main.c, line - 490
    Status raised : module - G:\s82\translators\brd2odb\brd2odb.c, line - 463
    Failed to translate job !!!
    Status raised : module - G:\s82\translators\brd2odb\brd2odb.c, line - 1832
    *********** WARNING  08Jan2010.162611.401  868  8.2.0(86) Windows XP
    T r a n s l a t i o n   e n d e d    W i t h   E r r o r s
  • redwire
    redwire over 15 years ago
     Cave--check your spaces between "set" and "path" --> "set path" not "setpath"
  • CADcaveman
    Yes I saw that tried that still the same thing . Refuses to run for me. I tried getting the UNIX version and running that under CYGWIN and it could not read the binary. So I guess CYGWIN and Sun OS binaries are not compatible.
  • mcatramb91
    mcatramb91 over 15 years ago
    Hey Carl,
    The only Windows Environmental variable required is ALLEGRO_BRD2ODB which should point to the folder where the translator is installed (where the BRD2ODB.EXE is located).  Also inside of the translator folder you will find the a folder called NV\BIN which contains the compress, gzip, etc. which it will find automatically when running the translator.  You do not need to set the PATH Environmental variable just the ALLEGRO_BRD2ODB.  When running it on the DOS Command line type the following:
    $ALLEGRO_BRD2ODB\brd2odb -d -gz -jn CU03_08A.odb CU0310708-00-A.brd
    You may have everything setup correctly already and having another issue but I figured I would run thru the setup above so you can double check.  There may be an isolated issue with the translator version you are using but I have never seen this before.
    Hope this helps,
    Mike Catrambone
