  3. Down Coverting to 15.5
  • Subscribers 162
  • Views 14549
mfshakir
mfshakir over 16 years ago
Hi ,
I am trying to convert my pcb file from 16.2 to 15.5 but it doesnt shows lines & clines. any help is appriciated.
tegatds
Faisal
  • Nagaraj Shanmu
    Nagaraj Shanmu over 16 years ago
    Faisal,
    With cadence tools you cannot downrev to major releases say 16.x to 15.x but you can downrev with in sub-release directly say from 16.3 to 16.2/16.0(file->export->save design to)
    How I do from major release i.e 16.x to 15.x is
    - extract the library from the design, use the downrev  command ( look in installation path Cadence\SPB_16.2\tools\pcb\bin)
    - extract the netlist from the design using tools-->reports ( flow is to use Third party netlist import)
    - export all elements from the design using subdrawing ( make sure you select all in find filter) - remember you need to select all options in OPTIONS  like preserve refdes, nets of shapes, nets of vias, testpoints
    now open a new drawing file in 15.x
    - Modify your library path to extracted library path in above steps
    - import the third party netlist exported in above step
    - import the subdrawing  exported
    you can also export the constraints using the topology file export or from constraint manager as 'dcf' file ( some constraints will give error as they are not supported in downrev version so you make have to redo manually)
    things to remember
    - if you have any user defined subclass in 16.x you need to create them, also stackup details also need to be created  in 15.x before importing subdrawing
    - text block settings should match in both design
    As there is no direct support from Cadence for conversion I use this as workaround.
    Few issues you will face while doing this downrev but can be solved looking into the errors case by case.
    Good luck!!
    ~Nagaraj.
  • mfshakir
    Thanksyou very much Nagaraj i will try and let you know.
    Regards
    Shakir
  • Rik Lee
    Rik Lee over 16 years ago
     In addition to exporting the clines etc using subdrawing you should export a placement file (File >Export >Placement) which you can then use to place the parts in the 15.X desing (File >Import >Placement).
