  3. startup file for PCBEditor
  • Subscribers 162
  • Views 16913
tltoth
tltoth over 16 years ago
Hi
Is there a way to import my parameter file automatically at startup?
thanks
  • oldmouldy
    oldmouldy over 16 years ago
    Yes, this is the outline of what to do:
    Record a script to import the parameter file.
    Save the script in one of the default "scriptpath" locations or set the script path as required to pick up the script.
    Set the "script_startup" User Preference to use the parameter import script just created - see the User Preference summary for details of what needs to be set in the value.
  • tltoth
    Thank you!
    Is there a command for displaying variable values like the contents of $parampath etc.?
  • oldmouldy
    Check the "expand" button at the bottom of the User Preferences form when you have the specific preference open for editing.
  • BillAcito
    BillAcito over 16 years ago
     Type "set" at the command line.
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    If you know skill programming I would recommend that you look at axlTriggerSet. This function will allow you to run a specific command everytime you open a board file (e.g. import the parameter file (through skill or script) each time a board file is opened.
    If you use the startup script function it will only execute when you run PCB Editor, not when you open a new file.
    Similarly the skill command can be used with close, save and other commands.
    Best regards
    Ole
