  3. DRC -> Adjusting constraints in Allegro
  • Subscribers 163
  • Views 2217
JGeens
JGeens over 16 years ago
I need a new DRC rule. But I dont know how I can insert the next DRC-rule: I need a spacing of 70µm from the soldermask of a (through hole) pin to a line segment (connection)...
I have changed this rule:
Line to Thru hole pin (2.8mils)
But I it doesnt seem to work.
 thnx in advance
  • redwire
    redwire over 16 years ago
     That works if the soldermask for the hole is 1:1 with the metal.  Is it?  It sounds like it might be oversized in which case you need to account for the sm clearance.
    If you get stuck, you can zip up a board and post it here but look at the sm definition first...
  • JGeens
     Where can I adjust the clearance rule or setting? I cant seem to find it anywhere...
     Thnx for your reply!
  • Rik Lee
    Rik Lee over 16 years ago
    In Constraint Manager use the menu selection Analyze >Analysis modes.
    Select the Design Options tab; You can add a clearance for SM to shape; SM to pad/cline.
    Enable the DRC check in the Design Modes tab.
    Update DRCs
    ~Rik
  • JGeens
     Thank you very much ;)
    I am learning new stuff and I like it!
