  3. PSpice Server Busy ver. 16.2
  • Subscribers 166
  • Views 13675
Johnnywu
Johnnywu over 15 years ago
I'm using OrCAD 16.2 with PSpice.
When I try to use PSpice, it always pop-up an error message and says "Server Busy".   I had 2 choices "Switch To" and "Retry".  Neither of them worked.  Any clue on this?
Thanks.
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    I would recommend that you install 16.3.
    A number of issues that could cause this situation have been solved in 16.3.
    If you run Windows Vista (or Windows 7 - although not supported yet) - right click on setup.exe and select run as administrator to get the sw installed properly.
    Also after installation - use right click on shortcuts and run as administrator (can be set as default on Windows 7 under the properties section)
    Have fun
    Ole
