  3. 16.3 Installation problem - Installinfo.txt
  • Subscribers 162
  • Views 1076
Johnnywu
Johnnywu over 16 years ago
 We are trying to install OrCAD 16.3.  The instruction says we have to save the installinfo.txt file during the server installation, but we didn't see such step during installation.  Where do we find the file?
Once we locate it, can we copy it to the client's end or we have to leave it on the server end?
Thanks.
  • redwire
    redwire over 16 years ago
     Installinfo.txt is sent to you via email when you purchase the tool.  It is used to select the proper items for installation so you don't load more than you need.  If you did not get it you should contact Cadence support not the user forum.
    That said you don't need it if you know what to select during installation.
