  3. Hide pin name in OrCAD Capture 16.2
  • Views 29355
Johnnywu
Johnnywu over 16 years ago
I'm making a customized symbol in Capture, but having problem hiding the pin name while showing the pin itself.  What I'm trying to do is making a symbol similar to the VCC/CAPSYM that is included in OrCAD Capture, in which I have the option to display or to hide the name (VCC).  For some reason, I'm not able to do this in my own symbol.  If I change the pin type to POWER, I can hide the pin and the name at the same time, however, it's not what I want.  I want to hide/show the pin Name instead of the pin itself.
Thanks for answering my question.
  • tltoth
    tltoth over 16 years ago +1
    have you tried to use options -> part properties ->pin names visible = FALSE in capture ?
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    You can generally turn pin name and number visibility on/off on a schematic symbol by doing the following
    1. open the part in the symbol editor (double click it inside the olb file)
    2. Either use Options, part properties or double click without hitting anything
    3. Locate the Pin Names Visible property and set it to false.
    Best regards
    Ole
  • tltoth
  • tltoth
     I'm sorry Ole! You won by 4 minutes :)
  • Johnnywu
    Yes, that works.
    Thanks a lot.
  • CookieMonstr7
    CookieMonstr7 over 12 years ago
    Great explanation, thanks!  I had this question, too.
