  3. Component disappears when I select it.
  • Subscribers 163
  • Views 16025
Prasanna
Prasanna over 16 years ago
Hi All,
The tool I'm using is Orcad PCB editor 16.2.
I'm working on a PCB in which I need to place components on the both side. Top side component placement is over. So I mirrored remaining components to Bottom side. Then I turned off the Top layer etch to get better view on bottom layer. Then I started picking up the components on bottom layer. When I select the mirrored components it diappears. I can see the rat nets connected to it, but not the components pad. I made some experiment. When I turned on top etch then I picked up a mirrored component, this time pads didn't disappear. I could see the bottom side pad while moving with top etch enable. But why not without top etch? same case with silkscreen.
Please let me know some tips. I dont want to enable top etch while placing bottom side components. That's going to irritate me..
please give me some idea...
Prasanna
  • jch teyssier
    jch teyssier over 16 years ago
     Does "strech etch" enable? It makes components desapear while moving...
    Jean-Charles
  • Prasanna
    Hi Jean,
     Thanks for your reply, but I have no idea where is that option. Please let me know some step points.
    Prasanna
  • jch teyssier
     Well, i am using 15.7,dont know  where it is "hidden" in 16.x.
    In 15.7: in "option" tab while move command is active
    Jean-Charles (not Jean)
  • Prasanna
    There is no "Option" tab in this version and I didn't find any "strech etch " option. If anyone know about 16.2 version please let me know.
    Prasanna
  • Prasanna
    I got the strech etch option. Actually if we take "move" command for placing the components then it will not disappear. But I'm using "place manual-H" command, which picks the origin of the component. Move command is working fine. I'm looking for place manual-H command. Sorry for not mentioning this point in the first post.
    Prasanna
