  3. BOM_IGNORE IN CAPTURE CIS-163
  • Replies 19
  • Subscribers 169
  • Views 25548
MAAC
MAAC over 16 years ago
 hi,
Is their an option where in i can generate a BOM while ignoring a component in the Schematic using Capture_CIS-163 something like wht it is in HDL
  • steve
    steve over 16 years ago
    Add property PSpiceOnly set to TRUE to the part in Capture amd this will remove the part from the BOM and the netlist.
  • MAAC
    is their any property exlusive for BOM n Netlist separetely...like BOM_IGNORE & PACK_IGNORE.... so that i can ignore the component only in BOM
  • MAAC
     basically i want a component in netlist but not in BOM....
  • steve
    I don't think this exists. I suggest you raise an enhancement request with Cadence directly.
  • slohcin
    slohcin over 16 years ago
    Could you set up a variant within CIS and mark the component as not fitted, then generate your BOM from this?
