  3. asymmetric pad shape. help!
  • Replies 9
  • Views 15278
vnick
vnick over 15 years ago
I need to built an footprint with asymetric pads. The required pad has oblong at an edge and rectangle at the other edge (QFN package).
Could somebody help me!
  • steve
    steve over 15 years ago
    Have a look at the atatched PDF file.
    different_shaped_pads.zip
  • vnick
    Hi Steve,
    It's a good point.
    Unfortunatelly, command Add rarc doesn't work (I use vers Orcad16.0). In that case I can't make the round side of the pad.
    Do you have other suggestion?
  • steve
    When you are in the add shape command change the options menu from lines to arcs depending on what you want to draw. This means you can draw a line, then change to arc, draw the round side then change back to line and so on....
  • vnick
    It works. Many thanks!
    Do you know how could I add soldermask/pastemask to that pad?
  • steve
    Using the same method. Just have 3 shapes, pad, pad_mask and pad_paste and in pad designer define the shape at each layer.
