  3. Color save function - PCB Editor 16.2
  • Views 4058
shangwu
shangwu over 15 years ago
Hi, I save my current color setting by clicking Display --> Color/Visibility --> Save Color Palette. For a new footprint project, I use Load Color Palette. It loads the right color palette, however, it does not show the correct visibility. I have to manually go to the palette and turn on/off the colors. How do I make it to show whatever the colors I had when I save the color palette? Thanks.
  • steve
    steve over 15 years ago
    You could also try view - color view save. You can store pre-defined views and use the drop down box in the views tab to access them. There is also a viewpath (under user preferences) so you can store them all in one location.
  • steve
