  3. Swap Parts
  • Subscribers 161
  • Views 17444
Swap Parts
Nampoothiri
Nampoothiri over 16 years ago
Dear All,
How can I swap parts  in Allegro Design Entry ?
For Eg:- In my first sheet , I have decaps (100 Nos) of  a particular value : 0.01 uF.
Now I have to replace all with 0.1uF.
What is the best way to do this ,other than cut & paste one by one ?
Can I select the decaps then all can be replaced with a new part at a shot.
Please advise. How is the general practise in Allegro Design Entry ?
  • tltoth
    tltoth over 16 years ago
    if their footprint are same and they differs only in value
    1. in Capture try Ctrl+F (find) then type c? (c1-c9) or C?? (C10-c99) or C*
    2. in the Find window (at the bottom of the page) select all the caps with LMB (left mouse button) + shift
    3. RMB -> edit properties
    4. look for value column in Browse spreadsheet.
    5. alter the value of the first row eg. 0.01uF -> 0.1uF
    6.click on the altered value -> copy
    7. select the cells at the same column below the first one with LMB+shift then paste
  • Nampoothiri
     Unfortunately Nop.
     The new part has different Footprint,Part name & other atttributes.
     Can I replace the existing part with the new one from library ?
  • tltoth
    then use "replace cache"
    in the project manager look for Design Cache.
    LClick on the part you wish to alter eg. "C"
    RClick -> replace cache
  • Jerry GenPart
    Jerry GenPart over 16 years ago
    If you’re using DEHDL (used to be called ConceptHDL), and not Capture,
    then select Tools> Global Update. This will allow you to replace all parts
    of one type (and with specific value) with another part (with different values.
    Jerry
