  3. Multi Layer Board Question
  • Replies 9
  • Views 17327
Dennis H
Dennis H over 16 years ago
I converted a 4 layer board (top,bottom, Pwr, Gnd) from Orcad Layout to Allegro 16.2.
Looks like everything came in but my power and ground layers are not connected. I looked in the display and it tells me they are there.
The rats nest is there for the power and ground layers.
 How do I go about connecting them to there respected pwr/gnd layers?
Any help is appreciated.
Thanks, Dennis
  • redwire
    redwire over 16 years ago
     Sounds like either the copper on the plane layers does not have an associated net name or the vias are not properly set up.  I suspect the first.
    You can always post up your board if this does not solve the problem.
  • Nampoothiri
    Nampoothiri over 16 years ago
    First ,Pls check the shapes has associated nets attached.
    Second, Pls check the shapes are static / Dynamic.
    Rgds,
    Sreekanth
  • Dennis H
     Thanks, for the info.
    I tried it and it don't seem to work.
    What I have is.
    This board was done in Orcad layout and it was done 4 layer board. We were asked to convert it to Allegro if we can. I converted it and everything came in except fro the Pwr/Gnd plane. What the board looks like is there is shapes where the diff Pwr and Grn planes are seperated. I tried to do what you had said but it didn't work. I know in Orcad Layout you setup a copper pour to the Pwr/Gnd planes you want. Is Allegro done the same way?
    Can you give me the steps on createing the planes?
    Thanks, Dennis
  • Rik Lee
    Rik Lee over 16 years ago
    In the Allegro menu select Shape >Polygon (or Rectangle)
    In the Options form set the following
           Layer
          Shape type (Static or Dynamic)
          Pick the net name the shape will be assigned to
    Digitize the shape
    Use the Right Mouse Button (RMB) to set the parameters (Clearances; Thermal types etc)
    RMB done the command
    If the shape is Dynamic the voids will be created if the Dynamic Fill is set to Smooth. Look under Display >Status under the Shapes category)
    If the shape is a static you will need to create the vioids using:
          Shape >Select Shape or Void
          Shape >Manual Void >Element
          RMB >Parameters. Set the parameters you need.
          RMB > Void All
    Hope this helps.
    ~Rik
  • tomoo
    tomoo over 16 years ago
    If the shapes are still there,
    Select shape -> RMB -> Assign net -> Assign net name: ex) GND or +5V -> RMB -> Done
    If the shapes are not there,
    Shape -> Polygon (or rectangular) -> Assign net -> Draw the shape -> RMB -> Done
    Tomo
