  3. How target nets in a relative delay group are determined...
  • Subscribers 163
  • Views 15797
How target nets in a relative delay group are determined in the specctra autorouter?
Neha Anu
Neha Anu over 16 years ago
Is there any specific rule for a net to be specified as a target in a match group?How can a target be explicitly selected in specctra?
Can anyone pls xplain this??
Thanx,
Neha.
  • tomoo
    tomoo over 16 years ago
    I don't know how to determine it in the specctra autorouter.
    However if it is in the constraint manager, I can explain the way.
    Usually, a target in a match group is assigned automatically.
    But if you want to assign the target to a specific net, you can do in the following way.
    Constraint Manager > Relative Propagation Delay > Open a match group > Enter "TARGET" in the "Delta:Tolerance" cell which you want a net to be a target.
    Hope this helps.
    Tomo
  • tomoo
    Hope this helps.
    Tomo
