  3. Allegro/SIP/MCM FREE Physical Viewers 16.3 released!
  • Replies 8
  • Subscribers 163
  • Views 8745
EvanShultz
EvanShultz over 16 years ago
 Grab it at www.cadence.com/.../downloads.aspx. You will need to sign in with your Cadence account.
 I don't want this to sound like an ad since I'm just another regular user of SPB, so here are some customizations/capabilities that I have been using or just discovered for the free viewer:
-Create an ALLEGRO_PCBENV env var on your system. The path of this env var will point to a directory (which you must create) analogous to the \pcbenv folder for Allegro. At the ALLEGRO_PCBENV location, you can put:
  •  myfavorites.txt to control the color192 form and custdatatips.cdt for custom datatips; exactly the same files as for Allegro.
  • An env file, which has only a subset of the full Allegro env. Mostly by trial and error I have found out what commands, or series of commands, can and cannot be used in the viewer. For instance, set viewpath works in the viewer and using that I am able to access site-level COLOR files which our manufacturing team uses to view different "layer sets" of a board.
-allegro_free_viewer.men at C:\Program Files\Cadence Design Systems\Allegro Free Physical Viewers 16.3\share\pcb\text\cuimenus to customize the Free Physical Viewer menu. As SKILL can't be used in the Free Physical Viewer, you must modify a MEN file instead of being able to use the new axlUIMenu* functions as with Allegro.
-You can put the same allegro.strokes file as used by Allegro at C:\Program Files\Cadence Design Systems\Allegro Free Physical Viewers 16.3\share\pcb\text, overwriting the default Free Physical Viewer strokes file, to add/change strokes in the viewer.
With these customizations in place, I feel much more comfortable using the viewer than the "out of the box" user experience.
I'm sure there are plenty other ways to modify and/or enhance the Free Physical Viewer, so if you have other tips you'd like to share let us know!
  • SpaceJosh
    SpaceJosh over 15 years ago
    Hi, The link does not work. Where can I get the free viewer? I always get the error: This webpage is not found. No webpage was found for the web address: ftp://orcad_sp:cdn99ORs@ftp.cadence.com/files/allegro/allegroviewers/files/allegro_free_viewer_16-3.exe More information on this error Below is the original error message Error 6 (net::ERR_FILE_NOT_FOUND): The file or directory could not be found. If someone has been able to download, please post the FTP link, not the HTML... seems several people get the same error.
  • redwire
    redwire over 15 years ago
    Link seems to be working...
    archive over 15 years ago
    I have the same problem as SpaceJosh above. I have tried IE and chrome. Is there an alternate way to download this file?
  • EvanShultz
    EvanShultz over 15 years ago
     Go to the Cadence webpage (cadence.com). Pick "Support & Training" from the list of gray text at the top, then select "Software Downloads" from the drop-down list. "Allegro FREE Physical Viewer" will be the 4th header in bold on the page. There you go.
  • mehtaabh
    mehtaabh over 15 years ago
    I'm trying to install Allegro 16.3 viewer on my Windows 7 64-bit laptop. However I keep getting error 1925 saying that I don't have sufficient privileges to install the viewer and I should try again after logging in as administrator. This is my personal machine and I am the administrator on it.
