  3. Allegro Design CIS pin naming
  • Subscribers 162
  • Views 14458
Mstrghettorigg
Mstrghettorigg over 16 years ago
Hello All, I was wondering if there was an easier way to name the pins for CIS symbols. I am trying to create a large Xilinx part with lots of pins by placing one then changing it to match the pin name and number. (pin name/number is not in sequence) Is there a way you could make a list or import an excel sheet to create pins? Any input will be appreciated. Thank you,
  • Mstrghettorigg
    Thanks again for the feedback. I was able to grab their ".pkg" file which contained the pin number and pin name and bank number. I was able to add other necessary info as suggested. Much X3 faster than what I was doing. Thank you!
  • Mstrghettorigg
