  3. fanout vs. pin escape
  • Subscribers 161
  • Views 15920
tltoth
tltoth over 16 years ago
Hi
Does anyone know what the difference is between fanout and pin escape ?
thanks
  • tomoo
    tomoo over 16 years ago
    Hi
    Usually, the fanout means that a routing trace is drawn out from a SMD pad and connected to a PTH or a via.
    On the other hand, the pin escape means it is a neck-down trace such as a trace between fanout vias or BGA pads or PTH pins.
    In addition, such as the following,
    Nominal Trace Width:6mil, partially 4mil(pin escapes only)
    Hope this helps.
    Tomo
  • tltoth
    Thank you Tomo!
