  3. Importing DXF into existing board design
  • Subscribers 163
  • Views 14819
stellar
stellar over 16 years ago
 I have an existing board design that I need to bring in some DXF data. I've got the board open and run the import/dxf and map the layers to a BOARD GEOMETRY class and a custom subclass name. I choose the units and it looks correct after import but my entire board dissapears. I'm not even sure the board design is in scope at this stage. On other boards I work from the mechanical design to the layout and import the DXF at the beginning but this one is my first attempt at loading into an existing board.
  • stellar
    Wow just clicked that box and you're message showed up at the same time.  Almost and ESP kind of occurence. Thanks.
  • stellar
