  3. How to set a particular layer for a pinpair in a groupset...
  • Subscribers 162
  • Views 14124
How to set a particular layer for a pinpair in a groupset in specctra autorouter??
Neha Anu
Neha Anu over 16 years ago
Hi all,
I'm using Allegro PCB Router(Specctra) for autorouting the boards.I want to set a particular net in a pinpair to a particular layer?
How is this possible to set in a specctra?Can anyone pls tell me how to set a particular layer for a net in the pinpair which is in a groupset (match group) MG1??
Thanx
Anupama
  • tomoo
    tomoo over 16 years ago
    All you have to create a layer ECSets and assign it to the net in the CM, you can autoroute on a particular layer using Allegro PCB Router.
    By the way, you are asking some questions about the autorouter, but it is never all-purpose tool.
    The specctra, a autorouting engine, is less-advanced since early times although Allegro is advanced.
    Particularly, there are problem with delay tune of bus line and diff pair routing in a complex PCB design, such as over 1000+ nets, a lot of DPs, MGs, and layer counts. It will not work if you don't lift some constraints.
    So I use the autorouter for an easy design or as an indication of estimation of total layer counts when floor-planning.
    I believe there is nothing like manual routing for now although I don't really know Global Route.
    Hope this helps.
    Tomo
