  3. Footprint rename pin
  • Subscribers 163
  • Views 17359
Adeshere
Adeshere over 16 years ago
I have a footprint for a connector BUT i need to mirror the pin numbers eg Pin 1 needs to be Pin 2 and Pin 2 needs to become Pin 1.
In Layout, i could get a list of the pins and there physical X and Y locations. This made it easy to rename the pins without physically moving them using cut and paste methods.
In PCB Designer, can i get a view of where each pin is to allow me to rename them ?
cheers
Adrian
  • redwire
    redwire over 16 years ago
    The footprints are stored as .dra files.  You simply open the .dra, edit the pin number and save.
    There are a few *understood* steps in there but that is the general idea.
    What is not clear is whether or not you created the footprints or if you just received a .brd file with the footprints embedded?
  • Adeshere
    The footprint is a previoulsy created footprint that i want to modify.
    I figured out how to change the pin number.
    1. Ensure nothing is selected
    2. Edit ->  Text
    3. Select the pin and then change the text, which is actually chaning the Pin number.
